ktmrfs
Jul 19, 2020Explorer III
GFCI will trip if:
1) there is a current imbalance between the hot and neutral load wires
2) There is a ground/neutral short.
A pretty common reason for a GFCI to trip in a trailer is moisture in the outside outlet on the GFCI circuit. Remove the moisture problem gone. Another possibility is the fridge electric element IF it is on the GFCI. Some are, and a failure mode can start as some low level leakage current to ground. To test, turn the fridge off or to gas, GFI ok, turn to electric and watch and see if it trips.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 25, 2026
