wa8yxm
Nov 23, 2020Explorer III
Gdetrailer wrote:
And wa8yxm, just so you can's say that there are no MSW inverters that work with GFCI I would recommend that you take a good look at a Trpplite PV3000GFCI HERE
I did not say they do not. I said I heard that there are GFCI's that do not play nice with inverters (Did not specify which type of inverter) but I'd never met one.
But when tribble shooting the more information we have. The better. So I ask the questions.
You are correct in how GFCI's Work.
Another question I forgot to ask is about neutral bonding. I did have an issue once when I did that wrong.. My Prosine-2000 and later freddom 2000 both have the option to bond ground and neutral in INVERTER mode or in pass through only. Well I lost a screw so I connected the two safety ground leads (bare or green) together. Did not work well.. Finally fixed it per the book for the device and it worked much better.
Having RV issues? Connect with others who have been in your shoes.24,376 PostsLatest Activity: Apr 09, 2026
