ajriding
Nov 25, 2020Explorer II
Agree to unplug everything from every outlet to make sure those things are not the issue. If one item is wired backwards (black and white wire switched) then it will trip.
Also, though unlikely in your story, that the inverter is wired in backwards.
By backwards I mean the two flat prong male plugs, one has a wide blade and will only fit in the wide slot... Your appliance will work backwards or not, electrically it does not matter, but to the GFI outlet it does because the ground wire cares how the black and white wires are wired.
There could be a short to ground that does not matter electrically, but is a big safety concern and that trips the GFI outlet also.
Having RV issues? Connect with others who have been in your shoes.24,375 PostsLatest Activity: Apr 09, 2026
