3_tons
Nov 26, 2020Explorer III
obiwancanoli wrote:3 tons wrote:
Just saw your post...Prior to this trip (where all was previously fine) was there any work performed on your electrical system??
3 tons
No, everything had been fine
Question, do the GFI’s trip when on inverter power only or when genny is running??...Try to exclude one or the other - either can be impacted by a nagging floating ground issue...
Also, If you have modest skills, inside the main breaker panel you’ll see a buss bar where all the return white neutrals connect to (i.e. the inbound whites). By disconnecting one neutral at a time (each time with power off), while resetting the GFI’s, then powering up the system again - this will one at a time help ferret out the actual source (whether circuit or appliance) that’s causing these nuisance faults..As previously mentioned, it could even be a water heater or refer element, or moisture in an exterior 120v receptacle ...
Good Luck,
3 tons
Having RV issues? Connect with others who have been in your shoes.24,375 PostsLatest Activity: Apr 09, 2026
