Our Dometic refrigerator is popping GFCI breakers when it runs on 120 volts. I pulled the heating element and it has three leads, one of which is the ground. Connecting these directly to a GFCI circ...
Out of curiosity- do you have the RM8555 ? That's the only Dometic I am familiar with that has a 3 wire element. You could. I suppose, hook it to a non-gfi outlet, stick a milliamp meter in the ground line and see what happens, though that doesn't really pinpoint the fault. I was going to say you could stick it in the ground wire for the element, but the element is also grounded through the cooling unit.
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 21, 2026
