danwelch
Nov 13, 2015Explorer
GFCI question
Our Dometic refrigerator is popping GFCI breakers when it runs on 120 volts. I pulled the heating element and it has three leads, one of which is the ground. Connecting these directly to a GFCI circuit at home, the GFCI pops after about a minute – just like at the campground. If I reset the GFCI, it will pop again immediately - until the element cools down. This is very reproducible behavior. So I am replacing the heating element – but I am very puzzled!
My mediocre electrical knowledge would suggest that the energized element is shorting to ground (the element casing) once it heats up and expands. However – here is the odd part – my Fluke electric meter says otherwise. The element has two white leads and these ohm out at 102 ohms. Spec says 104 ohms - excellent. The meter shows NO continuity (infinite resistance) between the white leads and the ground wire - even after the element is heated up and the GFCI is popping. The ground wire and the outer casing of the element are connected – near zero resistance. (That is appropriate.) So, what gives? Why is the GFCI popping?? Any ideas are welcome!!
