westend
Feb 13, 2014Explorer
Please, if you're going to text a long message like the original post, use capitalization and paragraphs. It's difficult to read.
A GFCI will not work if there is no power available to it. Start at the source side and measure with a hand-held meter if you have power at the circuit breakers. It could be a shore power cord problem.
The light problem is related to your 12v system. Either a switch has failed, a wire is loose, or a bulb has failed. You can also check all of your 12v fuses to make sure they are OK.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
