CA_Traveler
Feb 14, 2014Explorer III
It's also possible that it's wired correctly and you have a ground fault. Moisture is common so check outside plugs and all plugs near water, like sinks, HW and refer.
You can also buy a relative cheap wire tracer which can help to trace the wiring. You connect the transmitter to one end of the wire and use the receiver to trace the wire.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
