mackaycamp's avatar
mackaycamp
gfi problem
I have my trailer plugged into our house outdoor gfi outlet. All is working, but over time the gfi in the trailer pops, but not the outdoor gfi.
Do you think I have a weak gfi in the trailer or need to search further
Thanks
  • DrewE's avatar
    DrewE
    Explorer III
    Lots of possibilities...
    • The GFCI in the RV could be malfunctioning or otherwise need replacement.
    • There could in theory be a neutral to neutral fault in the RV that's rightly causing the RV GFCI to pop but not causing a fault to trigger the house GFCI. That's not very likely, but it is a theoretical possibility.
    • There could be an actual fault and the RV GFCI for whatever reason is just a bit more sensitive or faster to pop.
    • The house GFCI could be miswired or broken and not providing ground fault protection. Have you tried its test button lately? Does the outlet remain powered when it's tripped (which indicates that its line and load connections are swapped)?
    All that said, replacing the RV GFCI is not an unreasonable first stab at solving the problem if everything else seems kosher.
  • GFCI's do get old and start acting up. RV's use a standard part that you can get at any home improvement place.
  • If it has gray whiskers I would replace it. Electronic devices do not last forever, especially those that have to put up with campground idiosyncratic AC.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
