joshuajim's avatar
joshuajim
Explorer II
Dec 26, 2020
GFIC tripping
The barn GFIC is tripping on my Wildwood with Dometic RM2652. I has happened 2 times so I replaced the GFIC with a new one and it tripped again. I turned the refer on in case we needed extra storage at Thanksgiving and again at Christmas. It seems to be related to the refer. Electric heater element? Everything else is off other than the converter during storage.
  • jkwilson wrote:
    Has it ever worked normally on this outlet? Does your rig have an onboard generator?
    It has worked for years on that outlet, but since I replaced the GFI it's a moot point. No generator.
  • 2oldman wrote:
    I think it's a GFCI
    You would think that after more than 40 years as a licensed general contractor I should know that :o Fingers started typing before brain was engaged!
  • Does it trip breaker on propane mode? Use just your battery to see if it runs on propane.
  • Has it ever worked normally on this outlet? Does your rig have an onboard generator?
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
