Kayteg1
Aug 24, 2016Explorer II
2nd night would indicate that air from propane pipes was already bleed?
Do you hear a click at about the same moment when the igniter starts sparking?
Might take 2 persons to do the test.
Check for loose connectors. When new appliance can fail, most often a screw is simply not tight enough.
Also spiders are well known flame killers.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
