crosscheck
May 19, 2016Explorer II
smkettner wrote:
Go Power does not make inverter/chargers nor inverters with a transfer switch.
The inverters are excellent. I recommend to stick with sine wave.
I prefer separate components so Go Power is a good fit for me.
And yes I have the GP-SW2000-12
http://gpelectric.com/products/inverters
The reason that I asked the question was that my Xantrex Freedom 2000 SW(5 years old) is kaput. So I must replace it. The fault code(F04) says it is the AC transfer relay. The new generation #815-2012 Freedom 2000 SW (12V),is exactly the same except for newer engineered electronics so it would be easy to install and I can use the same remote but in 5 years will I have to replace it again. Are there better products out there, Chinese or otherwise? I would like a combo inverter/charger.
Dave
