Tom_M1
Jan 30, 2019Explorer
The two pictures depict thing same thing. You have to disconnect the converter from the AC breaker box and connect it to the transfer switch. This will work if you plan to manually unplug from shore power then plug into generator. I was overthinking the problem a bit. Newer motorhomes already have a generator/shore power transfer switch.
