Vintage465's avatar
May 03, 2015
Going Solar!
Hi, new to this forum. I am a many years of experience Travel Trailer type RV-er. We do most of our camping "dry" with out hook ups. My wife and I are getting ready to buy a new trailer that will come solar ready. It is solar ready on the roof with the quick connect. So, this is what I know, or think I know about Solar. A ten amp panel is for maintaining. Something like a 85, 100, 150 is for charging after pulling the batteries down. Big panels put out like 19volts so a regulator of sorts is necessary. I have heard there is a type of reg. that converts the excess voltage to amps and somehow makes use of those amps in the charging? Any help would be great. Web sites, dealers or distributors would be great.
V-465
  • I would disagree with pretty much everything fishinghat said.
    Solar is a great addition to any boondocker's charging line-up. With enough solar, you will not need a generator in many cases.
    Panels are rated in watts, not amps, and basically come in two voltages... 12v nominal and 24v nominal.
    The charge controller you refer to is known as an mppt controller... maximum power point tracking. The other option is a pwm controller... pulse wave modulation. Actually, both are pwm, but the latter lacks the ability to track the maximum power point.
  • First off, almost all solar panels will only produce enough electricity to keep a charged battery charged up, but not to re-charge a run down battery.
    Second thing, solar panels are big and expensive. Unless you are willing to spend some serious money on panels that will set out on stands pointing at the sun and storing them when you are not there, forget that option.
    Third. I'd suggest what most people who dry camp a lot do. Buy a Honda or Yamaha "quiet" generator and charge your battery(s) for an hour or so in the morning and evening.
    Go9ing off topic here, but if you plan to do a lot of dry camping, consider switching to two 6 volt deep cycle batteries if your rig doesn't already have them. They work much better than 12 volt batteries, even if they are marked "deep cycle".
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
