mena661
Apr 08, 2014Explorer
Shwthomas1975 wrote:It could be that but I would check it with a meter before replacing. The voltage should be the same on both terminals of the auto-reset breaker. Use the frame as ground. There also (usually) two reverse polarity fuses on the converter itself. Check those too when you get the meter. Remove the fuses and use the Ohms function on the meter. Should read 0.
Thank you all so much. mena661, I have one of those on the neck of the trailer which has the positive wire going to it and leaving it. It looks awfully corroded. What does that do? Is it just like any other fuse? Just needs replacing? Don't think I can read anything on it. Are they all the same? Thnx
So, would that cause the charger to not charge the battery? But would the lights and all still work?
Thnx again
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
