tenbear
Apr 08, 2014Explorer
Shwthomas1975 wrote:
Oh man. I will go get the meter and try that. Little confused but maybe it'll get clear when I see it. :) What should the voltage be on both terminals?
Thnx again.
One more ? So this meter I'm to get should be able to check volts and ohms? Anything else? Sorry if that is a silly question
You can measure the voltage across the circuit breaker. It should be zero if the CB is good.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
