AllegroD
Apr 08, 2014Nomad
Sorry, but I would not get the above for this diagnosis. It is good at showing what is going through that socket. There is value to that. To run down a problem, you want a 120/12v volt meter with probes, so you can test all lines and components. You cannot test the relay with the above.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
