mena661
Apr 08, 2014Explorer
Unyalli wrote:But a meter doesn't need a 12V socket to work. He needs the meter.Kiwi_too wrote:
Sorry, but I would not get the above for this diagnosis. It is good at showing what is going through that socket. There is value to that. To run down a problem, you want a 120/12v volt meter with probes, so you can test all lines and components. You cannot test the relay with the above.
Disagree, for a few bucks it's far better the 4 leds.
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 21, 2026
