BFL13
Apr 09, 2014Explorer II
You can't get 13.4 with no shore power unless you have solar and then it would be a fluke if its voltage were same as converter's usual voltage.
You still need to clean up the battery neg ground wire to frame connection to eliminate that connection at the frame as a suspect.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
