Shwthomas1975's avatar
Apr 08, 2014
Going to try to explain this....LOL...Need help
Morning.....First camping trip was last weekend in our hybrid trailer.
No power so used battery and generator.
Last year the battery would last quite a while. This time it lasted til about midnight both nights (woken by the blaring carbon monoxide detector LOL). Was running the heat, but that didnt matter in the past.
Did a little poking (I am no electrical guy). Noticed that when the generator was plugged in the 4 electrical charge gauge lights were only 2 high. Last year they were 4. When I plug it in, it's only 3.
I also noticed that when I turn off the breaker for the fridge, the lights dim and then go out. Took ff the cover and the fridge breaker also has the wire to the inverter. So when I turn off that breaker, the battery isn't charging anymore. But, why would the lights dim?
Any way to check for a bad breaker?
Any help would be greatly appreciated....
  • Two things contradict:
    With shore power on that means the converter (not inverter) should be on and that means you should get all the lights on the monitor even with no battery at all showing "full". Two or three out of four would indicated no converter on, just what the battery is doing.
    But, turning off the breaker to the converter (bright lights if the converter is working) would put you on battery (dimmer lights) so converter must have been working
    So either the converter works or it doesn't, which is it?
