This spring I'm upgrading to 6 volt golf cart battery's. My question is , do I need to upgrade the charging system of the camper ? The rv is a 2013 Palomino B-800. Any input ?
The rule of thumb I follow is to have around 20AMPS per battery of charge capacity. In the case of using two 6VDC batteries would fall under the two battery rule. This would need a minimum of 40AMPS of available charge current.
You can get away with smaller charge capacity but it will not recharge your batteries back in a three hour charge time which is what most folks want when camping off the power grid.
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
