If speed of charge (length of time) is an issue, then apply 14.8 volts to a battery at 50% depth of discharge and the amount of AMPERAGE you see flowing under that condition sets the OPTIMUM upper limit of the capacity of the charger you should seek. If it's 83 amps, so be it. An 83 ampere charger would offer the optimum fast level of charge for that battery (series, parallel, it doesn't matter).
CONTROL of the amperage is another matter. There's no sense at all, if a charger starts out at 83 amps, then wimps down to say 45 amps with a battery still needing 35% of capacity worth of charging. The 14.8 volt level of charge at 20C should STAY AT 14.8 volts until the electrolyte starts bubbling. Then it can be backed off. The algorithm used in smart chargers seldom even gets close to this optimum,
For forum members foaming at the mouth to contest my recommendation, go back and read the first ten words of my response again.
When time is NOT an issue 20% of the total ampere hour rate is a great compromise. Around 45 amps.
For optimum life 5% of amp hour capacity is excellent. Ten amperes. Around 15 or so hours to recharge 50% depleted batteries.
It all depends on how stupid the smart charger algorithm is.
Now go back and re-read how I phrased "bubbling". Light bubbling is not vigorous bubbling. As batteries charge throughout the protocol, maintaining a slight cell bubbling is the best possible compromise between speed and plate erosion. This is where a smart charger is as dumb as dirt. They can't tell. Only a programmable charger can be tweaked to try and do this.
But if a battery is primarily maintained by shore power a person can get away with near murder, unless the battery charge un-control is something out of Frankenstein's Castle.
