This spring I'm upgrading to 6 volt golf cart battery's. My question is , do I need to upgrade the charging system of the camper ? The rv is a 2013 Palomino B-800. Any input ?
It may be an upgrade if you are replacing one 80 AH 12v battery with two 110 AH 6v batteries, thus giving you 110 amp hours to draw on at 12 volts. If one fails you get less than 12 volts and some electronics equipment will not function at all.
Using 6v batteries is more practical when you have four 6v batteries wired in pairs for 12v output.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
