MrWizard
Jan 25, 2017Moderator
quick note
you charge by system voltage NOT single battery voltage
if the system is 12v then you charge the series pairs, NOT one 6v battery
if he is doing a 12v system, then its a 12v charger
if he does a 24v system, then a 24v charger
so if he uses 6v batteries, charge the 12v pair, or the 24v string
NOT one 6v
if using 12v jars parallel for a 12v system (i have 5)
you can charge only one or two externally IF needed, but again that IS system voltage
never charge only one battery of a series pair
golf cars and scrubbers and pallet lifts
all run multiple batteries 24v, 36v, 48v
there are NO single 6v chargers for big 6v batteries
because they are never used as only one 6v battery anywhere
NOT one 6v
