j-d
Mar 13, 2015Explorer II
Good Stuff on Sale at Harbor Fright
I own all these items:
These are coupon prices, shown on harborfreight.com
Pancake Compressor 100-PSI $39. Best for tires up to about 60-PSI. It'll air 16" to 75-80, but agonizingly slow. Outstanding with brad nailer.
Electric (120-VAC) Impact Wrench. Amazed how well it handles Ford lug nuts at 140-ft-lb. The 7/8" socket called for is NOT one of the individual sizes HF sells individually. Got one from Amazon Prime $8. Best to use a six-point deep black impact socket directly on the wrench.
Multifunction Oscillating Power Tool $15. I was glad to get one at $39 a couple years ago, they started out at $59. Indispensable problem solver. But it's a little like an inkjet printer - a couple blades cost as much as a new tool.
1/2" HD VSR Hammer Drill $26. Mine is an orange one they dropped then came out a couple years later with this one. It's heavy but butt-kicking heavy duty. I'm talking 1/2" holes in steel, 20 passes through a brick wall with long 5/16" masonry bit.
18-gauge 2-in-1 Nailer/Stapler $16. This and the pancake compressor make you Master of Baseboards. IF, however, you do not plan to ever Staple, and I haven't yet, the anvil leaves a much larger mark on the wood surface than the one in a Nailer Only tool will do. Nailer looks like you used a Nail Punch to set the nails. This one looks like you used a small screwdriver. GET NAME BRAND FASTENERS
This Thing. Supposed to be a 1-HP shallow well pump. Wouldn't pop two sprinkler heads. The Myers I bought at ACE for 3x the $ will pop eight.
They can get three for the price of one Honda pump and the Hondas last three times as long. The problem is that either pump gets drenched in salt water, dropped overboard, left out in the rain. Long before either is worn out. Honda isn't enough better to survive that.
