road-runner
May 12, 2016Explorer III
4 ga is on the small end, but at 2 feet length I wouldn't be totally sure that's the root cause. How about the battery interconnects? If they're also 4 ga, there's a bunch more small wire in the current path. Try measuring the DC voltage at the inverter input while when the microwave is started, or power a 1500 watt space heater and measure the DC voltage at the inverter. I totally disagree with the 110 vs. 120 volt suggestion. At a higher voltage, conventional microwave ovens draw more power. Doing the opposite, lowering from 120 to 110 (if you were able to do that) would help.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
