djgodden
May 12, 2016Explorer
My mistake, I went from memory about the wiring... I was wrong. I purchased the GP Inverter Install kit, the cables were each 10ft of 4/0 gauge.
I've written GP and asked their opinion on what I can do.
There's a nagging voice in the back of my head telling me it's wiring at the batteries themselves.
Here's exactly what GP provided in a reply to that Amazon review. (I confirmed my unit is NOT a fleet version)
"Thank you for your comments on the GP-SW3000-12. We can help you solve many of the issues with this inverter to make it much more user friendly. We can adjust the output voltage of the inverter (110VAC) using the dip switches on the side of the inverter. We can adjust the output voltage to 115VAC or 120VAC. The reason the units are default 110VAC is it uses less amperage from the batteries to create the 110VAC as opposed to the 115 or 120VAC. Most devices will run off of 110VAC without issue. We are concerned that you have received one of our fleet versions of the GP-SW3000-12 by mistake. These units have a higher low voltage shut down set to 11.5VDC. Our normal version allows the inverter to run all the way down to 10.5VDC. this voltage is better for running larger appliances that give a false low voltage reading because of the size of the load. What we mean by false reading is when the microwave is on it will pull the battery voltage down quickly to 11.5VDC, yet when the load is turned off the battery voltage spikes back up to 12VDC which is a reasonable level. We still recommend using deep cycle batteries with this unit and with a change in low voltage shut down to 10.5VDC this should correct and shut down issues that you were seeing. For your application I do recommend keeping the unit out of power save mode and just turn the inverter on with either the GP-SWR-A remote or the GP-SWR-B remote when you would like to run a load off of AC power from the inverter, and turning the inverter off when you do not require AC power. Please contact us at gopower@carmanah.com and we will start the process of sending you the correct version of the GP-SW3000-12 with the correct low voltage shut down."
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
