djgodden
May 12, 2016Explorer
Boon Docker wrote:
You say you are using a 50 amp cable. The voltage drop using that cable would be real high, seeing as the inverter is going to draw at least 150 amps or more on start up of the MW.
I purchased a 50 amp power cable just like the one powering the trailer when on shore power. Clipped off the shore end and hard wired it into the inverter. Then I plug it in.
Wouldn't that cable be ample since it's designed to run a 50 amp system?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
