time2roll
May 12, 2016Nomad
djgodden wrote:IIRC There is a switch up in with the hardwire connection.
Not sure how to increase VAC output.
Even 10' of 4/0 seems long. Mine are 5.5' and you said the inverter was close to the battery... did you shorten the cables?
Might want to do some testing with a space heater or hairdryer as the load is adjustable. Get some battery terminal vs. inverter terminal voltage readings at 1000w and 1500w loads.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
