MrWizard
May 16, 2016Moderator
the battery 'ground' cable, seldom has anything to directly affect the inverter
the inverter should be hard wired with (2) cables neg and pos, directly to the battery, NOT the frame ground neg
corrosion or loose connections where the cable are joined do cause problems
the house RV batteries are usually neg grounded, for two reasons, the house RV systems and the alternator chargeing while running, and have nothing to do with using the inverter
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 28, 2026
