Naio's avatar
Naio
Explorer II
Jun 09, 2017
Got my new (used) batteries!! Now, how do I rejuvenate them?
After a YEAR of Murphy's-law delays (his health, my health, getting stranded on the way there, etc., etc.) I have finally got my hands on 4 Fiamm 132aH, Just like Mr Wizard's.
I figure I should check in with you guys 1st, rather than just stick them on a charger.
They range 12.33-12.68 volts right now, with no load. I think the middle two were 12.49 and 12.66.
The Fiamm spec sheet says they like 14.1-14.4v charging, 13.62 float.
I have a PD9280 and a NOCO gen charger that puts out 10 amps. The PD says it puts out 13.6v, but ISTR there is a trick to get it to do 14.4? The NOCO is uber-smart, when I put a meter on it it seemed to do a slow cycle between 13.6-13.8v. No doubt it does other stuff when I am not looking. I could make it do 20 or 30 amps if I put clamps on the other outputs.
I also have 24v chargers: A just-arrived ebay Meanwell that can do 28v 10 amps, and a couple 5amp-ers.
Should I charge these guys separately because they might respond differently, or connect them in pairs, series or parallel, so I can give them high amps (PD) or high volts (Meanwell)?
Or should I order that adjustable volts and amps ebay power supply and give them fixed amps?
I want to do right by these batteries after going thru so much to get them! And the new van, but that's another day ;).
  • Condition them...
    20 amps min charge rate voltage setting to 14.7. Leave one battery at a time on charger until amperage each battery says less than one amp going in. Disconnect. Rest overnight. If amperage then exceeds one amp at 14.7 volts for longer than 5 minutes leave at 14.7 for 8 hours.
  • Hi Naio,
    You need to add the wizard to the PD for it to be able to do 14.4. There will be voltage sag due to the design of the PD, so you may have to "trigger" bulk mode (14.4) more than once.
    I would do each battery one at a time.
    Are those voltages "resting"? Mine sat for 30 days after I used a "genius" charger on them and voltages were higher than yours.
  • Naio's avatar
    Naio
    Explorer II
    Edit: I meant the health of the guy who had the batteries, not our dear MrWiz, who afaik is fine :).
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
