Matt_Colie wrote:
If you give us a hit what it supposed to do and where you got it, someone might be able to help.
It look like a DC Buck/boost, and as such, you are setting an output voltage and a current limit. Set the voltage where you want it and turn the I limit down until it shuts off. Then go back a little.
Matt
Sorry, this is essentially a continuation of several earlier threads on the subject of manual battery charging. I probably should have just continued on the previous thread, it would have made more sense. Anyway, you are right, it is a DC buck/boost.
