Searching_Ut
Jan 15, 2017Explorer
BFL13 wrote:
Solar controllers only show what the solar panels are doing, not what is going to the battery and how they are doing. Solar output goes to rig systems first, and anything left over goes to the batteries. Same with converters.
A Trimetric monitor on the batteries only shows what is happening with the batteries, including whatever the solar can provide from upstream of the Tri's shunt. You have to subtract the Trimetric amps from the solar amps to see how many amps are going to other loads.
There is a solar controller that has two shunts ISTR that does both jobs, forget its name.
If you use the Bogart SC 2030 as your controller in conjunction with the Trimetric 2030 you can look at both solar output and how much is going into the batteries. Of course a trimetric will also measure battery current while you can look at the solar controller to see what the panels are putting out and get the same info, just have to look at two displays.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
