MrWizard
Aug 20, 2017Moderator
i set my charge 'boost' 14.8v
set time for 4 hrs aka 240 minutes
return to charge if voltage is below 13.4v
i have NO loads thru the controller, so LV shut off doesn't count
we full time, so i want max solar everyday i can get it
and i want max solar to come back on, when the generator is turned off
so if voltage drops below float because the fridge came on or i used the MW
i want the solar to kick back into high gear and goto 14.8v
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
