RDMueller
Aug 29, 2017Explorer
I'll give that a try. Sounds like android has similar issues. In my case though, even one "read" causes it to go back to default numbers.
In your case, do you set battery type to "user" or do you select your actual type of battery? I started to think that if you select a battery type such as flooded, it has a set of default numbers for that battery type that can't be changed and you must use "user" if you want to use your own numbers. Only problem, I can't get it to stay on user. Even one "read" and it's right back to flooded.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
