dougrainer
Apr 26, 2020Nomad
No products, but just read what they claim they can do and buy and install per instructions. The MAIN thing to do is, when packing up to go home and you do NOT have access at home for dumping, fill and drain the Gray and Black tanks 2 or 3 times. Then after doing this, install 1/3 tank with fresh water install the Tank chemical and this will slosh on the way home and clean the sides of the tanks. Yes, time consuming, but if you want the system to work, do what needs to be done. Doug
PS. buy and install a clear dump hose adapter so you can see the condition of the waste when flowing out. Keep filling with fresh and dumping until it flows clear.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
