MDKMDK
Sep 06, 2018Explorer
Not sure I understand the problem, have no idea why it would plug like described, but I would say you've got nothing to lose except making things worse, and creating some additional mess.
Are there any plumbing diagrams that might show an alternate access point to dump it, like a capped cleanout drain somewhere else underneath the unit?
My Navion has a macerator pump to empty the gray tank, but if it fails, there's also a cleanout drain located near the tank along the drain pipe. I've already set it up as a failsafe, by adding a valved, capped drain plug in place of the screw in hard cap.
Good luck.
Good luck.
