Wulrich
Jul 14, 2022Explorer
ernie1 wrote:
Make doubly sure the traps under your sinks have enough water in them to form a seal that will not allow sewer gases back into the coach. I had that problem in the past where after traveling for a bit of time or after having just dumped the gray tank waste which might siphon out the trap, I would get a foul odor from the gray water tank. Nowadays, I try to remember to screw down tightly the sink drain plug which prevents the loss of liquid in the trap.
I’ve checked the p-traps, they were good.
And I don’t get the smell if the ac’s are off at all.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
