Wulrich
Jul 15, 2022Explorer
JimK-NY wrote:
Do I understand there are no odors unless the A/C is running? If that is the case, I don't see any connection with the grey water. I would check the A/C. Maybe a dead critter in the unit. As mentioned the A/C does not pull any outside air so the offending item would be inside in the A/C or ductwork if there is any.
No odors unless the A/C is running. The A/C smells perfectly fine unless I’m running the kitchen faucet, so it’s hard to believe that there is something inside the unit that is making it stink. But I will check
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
