Itinerant1
Jul 15, 2022Explorer
Lantley wrote:JimK-NY wrote:
Do I understand there are no odors unless the A/C is running? If that is the case, I don't see any connection with the grey water. I would check the A/C. Maybe a dead critter in the unit. As mentioned the A/C does not pull any outside air so the offending item would be inside in the A/C or ductwork if there is any.
The AC does not pull outside air but it does circulate interior air if the break or smell is present in the roof line or attic area it will drift into the AC duct system which is not 100% air tight.
Once the smell enters the AC duct the AC system blows the foul air into the interior of the RV where it becomes a noticable bad smell.
Why I mentioned to check vent pipes at roof line if everything else isn't curing the issue, can't hurt to check.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
