ktmrfs
Jul 17, 2022Explorer III
wa8yxm wrote:
Question: Many advise that when you are on a full hook up site to close your black tank (And they explain the reason I won't here) but leave the gray open till you are getting ready to leave.
NO. Close both valves and dump when you have to.
Why?
Ever see the ads for the RV Black Tank treatments that basically are a waste of money.. A Stinky RV that everyone is avoiding?
Well the Stink is not coming from the holding tanks ..it's coming from the park's sewer system up the 3" hose and into the GRAY tank via the open valve.> Close the valve to block the stink..
EXACTLY ON KEEPING VALVES CLOSED!!!! sewer lines doesn't have a P trap. I remember being at a park several years ago where one camper was complaining to the park about sewer smell at their sight. Cause.... dump valves open.
And a grey tank that is not occasionally cleaned can smell as bad or worse than a black tank. Occasionally before I dump I'll add some laundry detergent to the grey tanks, let it slosh around overnight then drain.
