mobeewan wrote:
camperdave wrote:
It sorta sounds like your vent pipe has slipped to the bottom of the tank.
Might not be all the way to the bottom of the tank but definitely sounds like the pipe has slipped deeper into the tank.
OP - the vent pipe should also be sticking above the roof. The vent pipe needs to be pulled back above the roof and new sealant allpied around it before water gets into the roof and the roof becomes water damaged. Be careful not to completely pull the pipe out of the top of the tank.
This is a strange problem for sure. But I agree with the above as the most likely cause.
