evy
Mar 04, 2016Explorer
2oldman wrote:evy wrote:You better buckle up.. it may get rough in here.
When I can dump the gray water on the ground I simply remove the plug from the drain inside the pump's temporary tank, the water is drained so the pump never comes on.
ok?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
