DutchmenSport
Mar 04, 2016Explorer
Even with your revised plan, the tanks themselves need to be vented, otherwise you've created a vacuum in them. If you don't have the sink tank open and draining, and the bilge pump is running, after the sink tank pressurizes, you'll start having water shoot out that vent. If there was no water in the p-trap in the sink, then the p-trap would serve as a vent. The vent needs to be just higher than the drain, that's all, but going to the actual tank so as it fills with fluid, the air can escape.
Reason why I said the pump would be a PITA, as stated above.... power failure, clogs, running your battery down, potential leaks. And how do you drain that system once the heat is turned off in the camper if you're not using it and temps get below freezing? Can you remove the bilge pump and winterize it? I suppose you can pour a couple gallons of "pink stuff" down the shower and feed it through the system, that would winterize it.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
