evy
Mar 04, 2016Explorer
DrewE wrote:
Another thing: your drain lines from the tank(s) should be larger than 3/4". A 3/4" line will take a very long time to drain. Standard RV bayonet fittings are 3" fittings. From a gray water tank, the drain line doesn't need to be 3", a 2" or even 1 1/2" line would likely be sufficient.
If you don't use a normal RV hose and connector, you'll probably have some trouble hooking up easily to dump stations that require the use of a donut or other seal on the sewer line. The bayonet fittings are also a lot quicker and less fidgity to hook and unhook than a garden hose screw connection.
Ok I understand 3/4" diam. is to small, how bout a flexible pool vaccum hose, they are 1-1/4" diam. they're light, cheap, quick connect. I saw many types of adapters on ebay/amazon for bayonet type connection, maybe I can add one at the end to connect to the camps site sewers?
The pump outlet is 3/4" diam. I think I can't oversize that one, or else the pump would fail to lift the water over the center aisle, right?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
