TakingThe5th
Mar 05, 2016Explorer
Maybe I'm missing something, but is there a way you could somehow tie the drain lines together below the floor while keeping the valves above the floor? With the drain lines coupled you could at least equalize the level in the tanks when necessary and also be able to dump tanks with one hose. If you dump the kitchen first, then the shower, your hose will also be cleaner for stowing.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
