evy
Apr 26, 2016Explorer
Hey guys, I'm trying to buy the pipes and fitting and I can't seem to figure out what kind of fitting go on top of the tank (3/4" vent and 1-1/2" sink drain)? Do I just drill a hole with my hole saw and insert my pipe in the hole? with silicone around the pipe?
My tank is not an ABS tank, it's actually a clean water tank, white plastic with one 1-1/4" tap and three 1/2" tap on top, can I use one 1/2" tap to vent the tank?
Also I have a 1-1/2" Valterra ABS blade valve directly on the bottom of the tank, do I simple use silicone between the ABS and white plastic tank?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
