Powder_pig's avatar
Powder_pig
Graywater drain valve sticking
I tried a search but didn't find this topic. The slider or gate valve for our graywater tank drain is getting hard to pull our or push in. Any suggestions as to an appropriate lube.
Thanks in advance.
  • if it's exposed, replace it... 4 bolts... you're done..
    unless it's cable activated.. then you have to find it first..
  • Direct connection or cable activated?
    If cable, lube the cable with Dri Slide.
    If direct, pour some olive oil in the empty tank.
  • Gjac's avatar
    Gjac
    Explorer III
    I put a grease fitting on mine, and pump a few ozs of grease in every other year, when it gets hard to move. It is usually my black dump valve that sticks first.
  • Any dry Teflon or silicon spray so no grit accumulates
    Good Luck, Mike
