Dr_Quick's avatar
Dr_Quick
Explorer II
Jun 26, 2017
Grease every where
Like many of the newer trailers, the one that I bought in 2015 had the Zerk fitting on the axles, which I think are useless. Being that the trailer is two years old I decided to pull the brake drums and check the brakes and bearings. I found lots of grease, but most of it was useless and some was what I would consider dangerous.
When I got the dust cover off, there was so much grease that I could not even see the nut and cotter key. Then when I go the drums off, the center of the hub was full of grease. Both places being a useless location for grease.
What disturbed me was that there was so much grease that it was leaking past the rear seal on all four wheels, and you could see grease going down the hub and it was getting on the "armature" and the electro magnet, which operates the brakes, about 1/4 of there surfaces were coated with grease. I would consider this dangerous.
Cleaned up the extra grease and cleaned off the Armature and magnet. So I feel safer now, and believe that my brakes should work better.:)
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
