otrfun's avatar
otrfun
Explorer II
Jul 11, 2016
Grease Fitting on Lippert Landing Gear
My rig is about 30 minutes away. Have some stuff to load in the next day or so and wanted to grease the two zerk fittings on each landing gear while I was out there.
Could be mistaken, but I thought I read somewhere the zerk fittings are a bit larger than a standard grease fitting.
Anyone know if the standard grease gun fitting will work? Or, do I need to purchase a larger grease fitting?
Thanks!
  • Filrupmark, SecondChance, thanks! Didn't know there might be a 3rd zerk. Will look close for that one.
  • Standard Zerks... however, there are three on each side of my Lippert front landing gear and I needed a flexible hose (rather than rigid tube) on the grease gun to get to several of them.
    Rob
  • ALL the Grease fittings I have used on all brands of jacks and motorhomes are the same size. Doug
